It is currently Fri Jun 19, 2026 11:30 am
 Post subject: Rudder issues
PostPosted: Sat Jun 13, 2015 8:19 pm
The H16 I've been trying to get into shape has a problem with one of the rudders. Both rudders have two holes in the top where it fastens to the upper casting. Not sure why two holes. I installed spacers to tighten the slop and new roller connectors. One of the rudders seems to work fine as it now seems to lock down when in use and says up when trailering. However, the other rudder won't lock down and trails down at a slight angle when trailering. I'm not sure how much cam wear is permissible. Could this be my issue?
Sent from my XT1080 using Tapatalk
 Post subject: Re: Rudder issues
PostPosted: Sun Jun 14, 2015 5:48 am
This probably isn't an issue related to cam wear. It almost certainly has to do with the holes in the bad rudder being in the wrong place.
Lay the good rudder on top of the bad rudder and line up all the edges - do the holes line up? If not, then fill the old holes in the bad rudder with thickened epoxy and use the good rudder as a template to redrill.
PostPosted: Sun Jun 14, 2015 6:37 pm
Bill Mattson wrote a good article with pictures on this in the May/June 1998 On the Wire (Vol 2 Issue 7) titled: Raking Rudders
http://www.thebeachcats.com/OnTheWire/wwwcatsail/archives/v2-i7/feature3.htm
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
