It is currently Mon Aug 03, 2026 1:40 am
PostPosted: Sun Jul 05, 2015 10:06 am
i have an '81 H16 (says the HIN). The sail number is 69201.
Is this the correct sail number, or are these sails from some other boat?
Is it sailing time yet?!?!?
PostPosted: Sun Jul 05, 2015 7:50 pm
I have # 65373 on an 83 hobie 16, so your sails may be slightly newer than that
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Mon Jul 06, 2015 9:33 am
Sail numbers are the serial number of the sail (for the most part) and have nothing to do with the hull number (HIN).
69xxx numbers would be from the very early 80's, so I suspect they are the original sails. You can also get a rough idea of the age by the sail color pattern, although certain patterns were made for many years.
Current sail numbers are in the 115xxx range.
Some boats will have a two or three digit number - they are from supplied boat/sail events where the sails are sequentially numbered for that event.
PostPosted: Mon Jul 06, 2015 1:23 pm
Cool, thanks for the data point. I have the tequila sunrise pattern.
PostPosted: Mon Jul 06, 2015 10:57 pm
http://static.hobiecat.com/web_uploads/2013/08/15/Hobie_16_Sail_Pattern_Guide2.pdf
2007 Hobie 16 - 'Slingshot'
1996 Hobie 18 - 'Onrails'
Hobie Bravo - 'Hobie Bites'
PostPosted: Tue Jul 07, 2015 7:00 pm
Very cool! Thanks.
