It is currently Sun Aug 02, 2026 7:58 pm
PostPosted: Fri Jan 15, 2016 4:55 pm
I broke a rudder off my 75 h16. A friend of mine who lives a few hours away has a rudder he thinks will work. Looking at the pics, I'm not sure they are the same. Can anyone offer advice looking at these pics?
Here is the non broken rudder off my boat.
Image2016-01-15_06-54-23 by Dom, on Flickr
Here is the rudder he has for me. They don't look quite the same but I don't know if thats just the angle of the pic.
Image2016-01-15_06-54-09 by Dom, on Flickr
PostPosted: Fri Jan 15, 2016 5:18 pm
My guess is that the second image is of an aftermarket / fiberglass rudder. It will work, but you may have a different feel from one tack to the other. Looks to have been drilled for a Hobie 18.
PostPosted: Fri Jan 15, 2016 5:31 pm
Would the 3rd lower hole be for the hobie 18? Should the top two holes work for the 16?
PostPosted: Tue Jan 19, 2016 6:17 pm
Top two would be from an older Hobie 18... 1986 or older.
PostPosted: Tue Jan 26, 2016 8:09 am
You would have to fill the holes with epoxy and then re-drill to match your "good" rudder. A very common and easy to do modification.
PostPosted: Wed Jan 27, 2016 8:59 am
Raking Rudders Correcting Helm on a Hobie 16 by Bill Mattson in Volume 2 issue 7 of On The Wire shows how to fill in and re-drill the holes in a rudder.
I have followed his method on several Lexan rudders and used JB Weld to fill in the holes while the rudders were flat with a piece of masking tape on the bottom. I do not have a drill press but have used a piece off of one of my broken rudders with a hole already drilled (for maximum rake) in it that I clamped to the rudder, so it would act as a guide for the drill bit of my hand held electric drill.
http://www.catsail.com/archives/v2-i7/feature3.htm
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
