It is currently Mon Aug 03, 2026 8:09 am
 Post subject: Help with rivets
PostPosted: Tue Feb 09, 2016 10:36 am
code material us sizes eu sizes qt
8010131 Stainles steel. POP 3/16x3/8 PH-SS 0,48 mm x 10 mm 22
8011231 Stainles steel POP 3/16x1/2 PH 0,48 mm x 1,27 mm 20
8010181 ? POP 3/16x1/4 PH 0,48 mm x 0,64 mm 24
8010201 ? POP 3/16x3/8 CSK 0,48 mm x 10 mm 41
Ref HC 16 Can anyone help me with material for rivets in this list ?
Thank you
Massimo
 Post subject: Re: Help with rivets
PostPosted: Tue Feb 09, 2016 11:11 am
All stainless. We don't use any aluminum rivets.
PostPosted: Tue Feb 09, 2016 11:56 am
Thanks a lot
PostPosted: Tue Feb 09, 2016 1:09 pm
I am a little confused. It seems to me that in all but two of the metric sizes, the decimal point (comma) is in the wrong place. The two that are correct are the American 3/8" length given as 10mm. I don't know how you would order them but you might want to check. The 3/16" size should be 4.8 mm and the 1/2" should be 12.7 mm.for example. Any that you use on the mast should also have the seals that go into the hole first. They look like tall top hats. When the pop rivet is set, they deform but maintain a seal so water won't enter the mast.
Howard
PostPosted: Fri Feb 19, 2016 6:21 am
Yes Howard you are right , I made some mistakes on writing down the conversion
Thank you for your interest
PostPosted: Sun Feb 21, 2016 9:52 am
I didn't mean to send critical but I did want to call attention to the water seal caps that go into the rivet hole before the rivet itself. The dealer I bought rivets from told me about them when I had to replace a cleat on the mast.
Howard
