It is currently Sun Aug 02, 2026 7:58 pm
 Post subject: Pre-90's shroud legnth?
PostPosted: Mon Feb 22, 2016 10:58 am
I need to replace my shrouds. My sails are older (83’), so they won’t cooperate with the modern rake settings on the 16. Is there a shroud length for the older set up? Currently, I have the shrouds at the lowest location on the plates. I know newer shrouds are shorter, but by how much? Do you think I could maintain my approximate rake with newer shrouds attached higher on the plates?
I’m a little over an hour away from my boat right now or I would just tip her over and measure them. I’d like to avoid the drive if possible and would love to have a new set to install the next time I go to the club. I’d rather not sail until they are replaced as there are some visible signs of fatigue.
Does anyone know of the length?
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Mon Feb 22, 2016 11:17 am
Yes... new shrouds are shorter, so move newer ones up in the adjuster plates to get to where you used to be in Rake.
PostPosted: Mon Feb 22, 2016 11:25 am
Thanks! I didn't know how significant the difference was. I appreciate the quick reply.
James
Sail # 76909
