It is currently Sun Aug 02, 2026 6:54 pm
 Post subject: Dull Hulls
PostPosted: Sat May 28, 2016 2:56 pm
Hey guys. I'm the proud owner of an early 70's vintage puke green Hobie 16. The hulls are screaming for anti-oxydizing and polishing. Anyone have any personal favorites for a product that can help me accomplish this with out having a coronary? I've always gotten really good advice on this message board. Thanks in advance.
 Post subject: Re: Dull Hulls
PostPosted: Sat May 28, 2016 3:25 pm
This video may help:
Hobie Catamaran Oxidation Removal by Surf City Catamarans
https://www.youtube.com/watch?v=74sEyot5A_o
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Mon May 30, 2016 8:38 pm
On something that age you may want to start out wet sanding with 800 grit, then 1200. I use polishing compound meant for clearcoat on cars to finish up.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Tue May 31, 2016 6:28 am
Good luck keeping that stuff looking good! I had an early red boat and finally gave up. Too much work which interfered with sailing time! :D
PostPosted: Tue May 31, 2016 8:02 am
When I restored my H16 last year, I used two products to remove the oxidation on the hulls and to protect them. My boat had sat outside, unloved for a decade.
I started with a thorough cleaning using a good boat soap and a soft brush to remove the dirt. Once dry, I applied Yacht Brite Buff Magic to a small section at a time and then went over it with a random orbit buffer. The more you work this product with the buffer, the better the results. After buffing off the oxidation and smoothing the gel coat with the Buff Magic, I applied Yacht Brite Pro Polish to protect the gel coat from further oxidation. It also put a like new shine on it. The finish is still holding up nicely after a full season. I will put on a fresh coat of the Pro Polish this spring to maintain the gel coat protection and shine.
Put on some Jimmy Buffett sailing tunes, work slowly and patiently, and the results will be excellent. Here are links to the products that I used...
http://shurhold.com/marine/yacht-brite- ... uff-magic/
http://shurhold.com/marine/yacht-brite- ... ro-polish/
I bought these at West Marine, but have seen them available from other marine suppliers as well.
Erich
S/V Sarge
1985 Hobie 16 Signature Model
Sail Number 82009 "Summer Games"
