It is currently Fri Jun 19, 2026 11:32 am
PostPosted: Mon Aug 22, 2016 1:07 pm
Hi,
First time posting on the forum, although I've consulted it several times for help. This time I searched the forum, but couldn't find an answer, so it seemed like time to jump in.
I have a 74 Hobie 16 that I purchased last year and just broke my second rudder. In both cases the whole thing snapped off about 6-8 inches from the top, just below the casing. The first time, I didn't have the rudder locked in the vertical, and google has led me to believe that was my fault. But the second one was locked down, in deep water, winds 10-15 mph, no significant pull on the rudder arm to speak of, just a little "pop" and most of my starboard rudder is horizontal rather than vertical. These are your basic white rudders.
Am I doing something wrong or do I just have rotten luck? I don't want to keep replacing rudders, they are too expensive to replace every season.
Thanks,
John
PostPosted: Mon Aug 22, 2016 1:59 pm
Classic... Old ABS rudders... they give up after awhile. New standard rudders are far tougher (Nylon).
PostPosted: Mon Aug 22, 2016 5:45 pm
Thanks!
Would you suggest new nylon, or used fiberglass?
PostPosted: Mon Aug 22, 2016 9:56 pm
The old rudders fail pretty easily when 30+ years old. I'd be searching for used Hobie EPO rudders. I've seen gen 1 ones go for $200 a pair and they're a modern design and tough. Any of the 80's fiberglass ones would be an upgrade too.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Tue Aug 23, 2016 4:05 am
Thanks!
I'll look for a set of fiberglass.
John
PostPosted: Tue Aug 23, 2016 11:11 am
I have a set of fiberglass that I would make you a deal on. Fiberglass are stiffer than the regular rudders but not as light as EPOs. I haven't used them and they are sitting in my shed. I can send you photos. Just let me know.
PostPosted: Wed Aug 24, 2016 7:08 am
PM sent.
