It is currently Mon Aug 03, 2026 1:40 am
PostPosted: Thu Sep 08, 2016 4:14 pm
I have the following parts, but need a sanity check to see if this is the right method to go about this;
Now does the rivet, go into the cap;
And then whole shebang goes into the part (and into the mast), and then riveted into place? Do I need to put any silicone or anything in/under anything?
This is a shot of the bad part;
Thanks!! Or maybe does the cap go in the mast first, then part, then rivet? *shakes head* :oops:
-Lyle
PostPosted: Thu Sep 08, 2016 7:29 pm
You've got it right in the first series of photos.
But it really doesn't make any significant difference.
Rather than silicone, use a bit of Tef-Gel (http://www.westmarine.com/buy/tef-gel-- ... P012222212) to minimize galvanic corrosion between the rivet/rivet cap and the mast.
PostPosted: Fri Sep 09, 2016 10:34 am
Thanks for verifying my plan of attack! I'll see about getting some of that gel before I start. Thanks!
