It is currently Sun Aug 02, 2026 4:29 pm
 Post subject: Tow with a prius?
PostPosted: Fri Dec 23, 2016 5:16 pm
Anybody out there towing their H16 with a Toyota prius? It looks like it can be done, just want to confirm.
I heard one guy doing it with a mini-cooper, so that makes me think the answer for the prius is a yes.
 Post subject: Re: Tow with a prius?
PostPosted: Sat Dec 24, 2016 10:01 am
For a 2016 and newer yes - http://www.carscoops.com/2016/04/new-to ... owing.html.
Anything older, no - at least not authorized by Toyota. Doesn't mean you couldn't get a hitch for it - http://www.etrailer.com/hitch-2010_Toyota_Prius.htm.
Almost any car can tow a Hobie 16. Except maybe a SmartCar.
PostPosted: Sun Dec 25, 2016 7:48 am
I think a big limiting factor is your speed expectation. Anything can pull a Hobie but once you start expecting 60, 70 MPH you may be putting a lot of unexpected constant load on the drivetrain. A conventional IC engine with clutch and gears can handle a lot but who knows about some of the Hybrid stuff. It's really good to see a tow rating for the Prius, in an age when it is rarer and rarer to see a tow rating at all.
A Smart car can probably pull a Hobie around town just fine, but a long highway trip might be more than the transmission was designed for. The wind drag from a towed catamaran is pretty big. My fuel economy (Jetta TDI wagon) can easily go below 30 towing the Hobie, from a typical 40~42.
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Tue Dec 27, 2016 7:57 am
I think that removing the tramp for a longer tow would make sense. It doesn't sit flat, and it catches quite a bit of air I think.
Steve
PostPosted: Tue Dec 27, 2016 9:47 am
Before I got my H16 I had looked at a H14 Turbo and when I went to see it, the owner was pulling it with a small Toyota Celica.
I pull my H16 with a 2006 Nissan Quest, it has a V6 and has pulled the Hobie for 4 hours to get her home after purchased, and I actually didn't see any real change in fuel economy.
Marty
Lake Martin, 'Bama.
PostPosted: Tue Dec 27, 2016 2:00 pm
I've towed my Hobie 16 all over the place with a Mini Cooper S - manual tranny. Had zero issues, even towed my hobie 20 with it a few times - never longer than an hour drive each way to lake tho. I would recommend something with a V6 if you're planning on going to regatta's ect a few hundred miles away. In that regard, a used Toyota 4Runner V6 SR5 can be bought for a few grand, great for boat/Camping/Regatta duties and not have to worry about tearing up your Motor/Transmission.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Tue Feb 14, 2017 11:36 am
When going to regattas, I used to double stack our Hobie 14's and tow them with a diesel V.W. Rabbitt. NO problem except a little slow going uphills!
