It is currently Sun Aug 02, 2026 3:15 pm
PostPosted: Tue May 23, 2017 4:37 pm
I just bought my first Hobie Cat, and I am very new to sailing. I noticed that something didn't look right with the bottom of my mast and the mast base. Are they broken? Are they still usable? If they are unusable, where would I get a replacement part?
PostPosted: Tue May 23, 2017 4:41 pm
Photos?
Parts are available through Hobie Cat dealers: https://www.hobie.com/dealers/
Select product type "Fiberglass Sailboats" and enter your location information.
Parts lookup tool: https://www.hobie.com/parts-and-accessories/
20200011 MAST STEP,H14/16 BLACK
20640011 MAST BASE H16 BLACK
21380001 MAST STEP LINK KIT H14/16
Rivets list on page 51: https://static.hobiecat.com/digital_assets/14-16_March_2017.pdf
PostPosted: Tue May 23, 2017 4:58 pm
PostPosted: Tue May 23, 2017 8:32 pm
Here are the links to the pictures.
I can't tell if they are broken or not. Thanks for the help!
PostPosted: Wed May 24, 2017 8:51 am
The base "hook" is broken. It is an old style. You can update to the newer version that uses a link. Makes it easier to step the mast by drilling a hole in that nub on the base and removing the pin in the step casting. Or, replace both parts.
Instructions: https://static.hobiecat.com/item_attachments/21380001z52.pdf
PostPosted: Thu Mar 01, 2018 7:14 am
The other day I had a "ghost ship" day when my boat sailed off from the shore without me. It capsized before I could get to it.
After up-righting it and sailing back to shore, I noticed that the mast step link was bent. Normally gravity keeps the step link down (while sailing) so it will not hit the mast base nub, but while capsized (or turtled), gravity can cause the link to swing out and hit the mast base nub and get bent.
Is it better to remove the mast step link after the mast is up each time or is there a way to keep the mast step link down against the mast step (while sailing)?
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Thu Mar 01, 2018 7:39 am
Some of the links are spring loaded to help hold the hinge down when not being used. But most people just use two pins so the entire link can be taken off after the mast is stepped.
PostPosted: Thu Mar 01, 2018 10:49 pm
I always take my mast step link off after the mast is up. Don't know why, just something I've always done.
Sledder does it better
PostPosted: Fri Mar 02, 2018 8:26 am
I guess I will use a second phillips screw driver instead of the bolt, so the link can easily be installed or removed.
Tim
84 H16
82 H16
87 H14T
Clearwater, FL
