It is currently Mon Aug 03, 2026 8:23 am
 Post subject: Trimming Battens
PostPosted: Mon Aug 07, 2017 6:23 pm
Just a quick question.
What is the best method for trimming the jib battens to make them shorter?
Marty
1984 H16 Yellow Nationals Redline, "Yellow Fever"
Lake Martin, 'Bama.
 Post subject: Re: Trimming Battens
PostPosted: Mon Aug 07, 2017 10:42 pm
1st off, I use Trentec luff caps and Hobie leech caps on the main. I made a small miter box to hold the batten for a square cut with a hack saw. The Trentec caps need a square cut, but they are angled to fit the various batten pockets. For Length I'll slip them into place and give myself 2 1/2" from the eyelet of the sail for the leech end and cap it off. This seems to allow me to use the recommended batten tie length.
For the jib, my dealer sells soft plastic luff caps that hold well in the plastic batten pockets. If a tie does come loose they hold the batten in place and also help to avoid a poke thru situation.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Tue Aug 08, 2017 10:22 am
Hack saw... short as possible and still get tension.
PostPosted: Tue Aug 08, 2017 12:59 pm
How do you keep the battens from splintering when cutting with a hack saw?
Marty
Lake Martin, 'Bama.
PostPosted: Tue Aug 08, 2017 2:19 pm
Saw with less pressure. You might saw all the way around to create a groove / ring. Then saw smoothly. Using less pressure as you reach the far side.
PostPosted: Tue Aug 08, 2017 3:18 pm
Okay thanks. I would imagine that once cut, I would probably want to smooth the edges with some sandpaper.
Marty
Lake Martin, 'Bama.
PostPosted: Tue Aug 08, 2017 3:43 pm
Yes or a file to make sliding the cap on easier.
PostPosted: Wed Aug 09, 2017 1:29 pm
Wait, the caps are removable? I figured I'd have to measure and cut the end that is opposite of the cap.
Marty
Lake Martin, 'Bama.
PostPosted: Wed Aug 09, 2017 1:43 pm
Yes... This, of course, will make it far easier.
Remove the caps. Stuff the battens and then push each in with tension... mark leaving enough with-cap to do what you want... cut, install cap... go!
PostPosted: Wed Aug 09, 2017 2:06 pm
Your caps may have been glued on by the PO. Best to leave them unglued and tie a stopper knot in the end so they can't get lost.
Jerome Vaughan
Hobie 16
PostPosted: Wed Aug 09, 2017 6:12 pm
Thanks for all rhe help guys.
Marty
Lake Martin, 'Bama.
