It is currently Sun Aug 02, 2026 10:11 pm
PostPosted: Wed Aug 30, 2017 4:09 pm
Hello,
I noticed that, every times, after sailing, when I empty the hulls, there are parts of fiber glass that comes out with the water. This happens on both hulls.
I bought this boat few months ago, and I didn't notice any repairs on the hulls. It is year 2000.
Here is the pic:
Dou you know if it is a serious issue ?
PostPosted: Thu Aug 31, 2017 4:31 am
Almost certainly not.
Are you sure it's not pieces of deteriorated polyethylene sheet? The flotation blocks (made of Styrofoam) are enclosed in a polyethylene bag during the hull assembly process to keep the resin fumes from attacking the foam. After so many years, the polyethylene becomes brittle and the motion of the blocks inside the hull breaks it into little pieces.
If it is fiberglass, it's probably just trimming shards that ended up in the deck (built upside down) or the hull during the construction process.
PostPosted: Fri Sep 01, 2017 5:33 am
Hello,
Thank you for you answer.
After reading your message I'm finally not sure that it is fiberglass. I am pleased to read that it's not a big issue.
Thank you!
Nicolas
PostPosted: Fri Sep 01, 2017 7:30 am
Just make sure it doesn't clog up the drain so much that the water won't completely drain out. Then you would have a problem.
PostPosted: Fri Sep 01, 2017 9:05 am
I remove it every times to be sure the water completely drain out!
Thank you very much !
PostPosted: Fri Sep 01, 2017 9:30 pm
I would be more concerned to find where the water is entering.
04' H16 107693 White/white-Sold
70's H14T 36396 sn 3986
83 H14T 61086 sn 5109
PostPosted: Sat Sep 02, 2017 6:22 am
That is definitely the polyethylene that Matt discussed.
Jim
PostPosted: Sat Sep 02, 2017 7:23 am
Thank you very much!
Concerning water: I need to find where it is entering. I will probably try to "inflate" the hull with air and find leak locations.
When sailing during 4 hours, in the left hull, there are approximately 0.5 liters of water. Much less in the right one.
Nicolas
PostPosted: Sun Sep 03, 2017 5:53 pm
In my book, 0.5 Liters in 4 hours equates to hardly worth the effort to search out the leak.
All the Hobies I've owned have leaked at least a little in one hull or the other.
