It is currently Sun Aug 02, 2026 1:51 pm
 Post subject: Topsy Turvy Tramp
PostPosted: Fri Feb 23, 2007 2:37 pm
I'm going to flip my tramp over when I install it this season. Am I going to run into any problems? It seems like it would be pretty straight forward, but most things do and then they turn into a nightmare. The top is so faded that it looks pretty bad. The bottom is still a nice solid yellow and will look much better. Any suggestions? Thanks loads.
PostPosted: Fri Feb 23, 2007 2:47 pm
That sounds like a good idea - but my good ideas usually turn into nightmares too! Looking forward to replies on this topic.
PostPosted: Fri Feb 23, 2007 3:06 pm
I am assuming you have a yellow vinyl Hobie trampoline. The only issues I can see are that there is no texture on the bottoms of these tramps (kinda slick), and no hiking straps (but these usually rot off by the time you have a sun-fade problem on the top anyways).
Old vinyl is pretty stiff stuff! Go slow and don't rip anything - and when you re-lace the trampoline, get it nice and tight!
Tim
http://www.hobiefleet72.org
PostPosted: Fri Feb 23, 2007 5:23 pm
If you have an upholstry shop nearby they might would sew some straps on for you. I just had it done to my tramp, I don't know the age but I'd guess it's rather old. They did it for 20 bucks and in like 15 minutes, and did a great job I might add, reinforced and everything. I had them sew on old seat belts for the straps, found them in a junk yard car. They'll probably last longer than what was originally on there but I think I'll probably need to keep them out of the sun when not in use.
James
86' Redline Hobie 16
Sail # 76909
 Post subject: TT Tramp
PostPosted: Mon Feb 26, 2007 10:18 am
Yes, the hiking straps have come off. I have seen some that have been resewn, but with a twist in them so that they stand up a little and you can get your foot under them easier. Personally I very seldom use them except to grab onto with my hands. If I need to hike, I'm on the trap. The tramp is also slightly brittle and will not tolerate any sharp bends. I have stored it in the shed this winter and will install it in a month or so. We just had a couple of snow storms come through Utah this week. Any ideas about how to restore the flexibility of the tramp? Thanks.
 Post subject: topsy turvy tramp
PostPosted: Tue Apr 03, 2007 9:31 pm
Flipping over the old vinyl tramp worked for me, using a new lacing cord. I didn't bother with hiking straps because I am just a beginner. I'll get an awning shop to sew some seatbelt material on next time.
PostPosted: Wed Apr 04, 2007 5:14 am
Yeah - get a new one. :twisted:
Seriously, if the straps are gone and you're considering flipping it over (the bottom is really slick when wet), it's time to look at a new trampoline.
 Post subject: tramp replacement
PostPosted: Wed Apr 04, 2007 7:53 am
With a sailing budget like mine, buying a new one is a multiseason savings task. You say, "get a new one", like you are talking about buying a Big Mac. Just not in my reality frame.
PostPosted: Wed Apr 04, 2007 9:24 am
If it is a purely cosmetic issue I wouldn't bother with flipping it as others have said, the bottom is really slick.
Many people get into cat sailing without keeping in mind the cost of maintaining the boat. I started when I was paying my own way through college. I worked alot of extra hours to pay for my sailing habit. You would really have a bad day with an equipment failure on the water.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
