It is currently Sun Aug 02, 2026 3:16 pm
 Post subject: shroud length
PostPosted: Tue Sep 04, 2018 5:44 am
mast base was change in '82 for more rake
will the 18'11" work?, they should right with the 10 hole chain plates.. :?:
I found this...
http://largiader.com/hobie/history.html
Model year history
Original main traveller car was sliding metal plate
Original mast step with hook
Early '70s - mast step or base changed to remove hook
1972 - main traveler with rollers
1977 or thereabouts - 3-hole mast tang
1982 - Shorter shrouds, longer forestay, modified mast step casting to allow for more aft mast rake.
1983 - double-grommeted rear tramp lacing
1984 - weight reduction 340 to 320, red adhesive
1984 - Adjustable rudder castings
1985 - Comptip and main halyard, reef points removed from main
mid-'80s flush boom vang fitting and then removed mid-'80s clear anodizing ended
1995 - shrouds shortened from 19'2" to 18'11"
- Updated corner castings (injection moldings) and trackless pylons, integrated jib and main traveler tracks
- jib traveller with cleat on pad riveted to crossbar, Delrin sliding car
- Miracle 20-style tiller connectors
1996? - deeper jib traveler track with brass-wheeled cars
mid-late '90s - updated bolt rope in sails
2000 - recut jib?
2004 - another mast step casting change to improve rotation
late 2005 - roller bearing jib traveler with cleat on car
2004~5 - EPO2 rudders standard?
2009 - shrouds shortened slightly to 18' 10.25" - bridle lengthened to 3' 9.5"
Unknown:
•6:1 main
•Aussie jib halyard system
•Double trapeze
•Trapeze adjusters and "Can't Miss" handles
•Coated wires
•One-piece, cast gudgeons
•Adjustable batten end caps
•Single-sided cutaway for mainsail track, deletion of sail feeder
Detroit..north of
 Post subject: Re: shroud length
PostPosted: Tue Sep 04, 2018 8:11 pm
the list looks like guesswork.
Main traveler was the slide plate til 75 or 76
They still had the hook system on the mast til 76
All masts had 3 hole tangs by 79
Increased aft tramp grommets came in 80
Increased mast rake was late 80s not in 82
Rake adjustable rudder castings came in 83
boom vang hanger was removed in 85
So you want to put 1995 shroud length on an 84 boat? and use 10 pin adjusters instead of the 7 pin
You may need to grind down your mast step to allow for the rake or replace the step.
But that's my guess. I see no difference in the 80-85 mast steps.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Wed Sep 05, 2018 4:19 am
an update
18'10.25" shrouds installed on 84 hobie 16
new frt stay 17"6" installed
frt stay on top hole of 10 hole chain plate
Mast was stepped with the side shrouds on top holes (10 hole chain plates) & frt stay connection was made.
side shrouds were able to be brought down to the 4th hole on each side
bridles are std size per the hobie wire guide for an 84
mast rotates freely & stops engage as they should
Detroit..north of
PostPosted: Wed Sep 05, 2018 5:15 am
With new shrouds & the 10 hole plate on my boat (76') only allows me to go to the 2nd hole down from the top before the old seaway's are block to block. Does this sound right? I'm in the process of converting to a lower profile. I always thought that the foot of my sail sits a bit lower than other pics I've seen, is that even possible?
PostPosted: Wed Sep 05, 2018 6:02 pm
Yes, sounds right, hobie wire guide has all the lengths for the different years, bridle length & lwr frt stay lengths figure in.
Maybe your frt stay is longer.
I dont know how the foot could be lower though..that seems strange
Like the stopper on the halyard is lower?
Detroit..north of
PostPosted: Thu Sep 06, 2018 10:19 am
I made a chainplate extension so that the old style front stay could be used. I bought a new halyard, the top of the sail sits where it's supposed to when the sleeve is locked into the tang. It's very possible that my eyes are playing tricks on me though, after taking a second look at other boats compared to mine, maybe it is normal. Where does the gooseneck usually sit with the downhaul off?
PostPosted: Thu Sep 06, 2018 10:32 am
ours sits just below the opening in the luft track
Detroit..north of
