It is currently Sun Aug 02, 2026 7:47 pm
PostPosted: Tue Mar 19, 2019 6:31 pm
The pin on my main halyard is gone. I noticed it would come out, though it is supposed to be captive. I will look through my boxes a few more times, and am looking for my old halyard (the missing pin is off a newer halyard).
I thought I would post here for a recommendation on a replacement pin. I would hope the pin is a standard diameter and thread, and maybe a standard length. I really do not want to replace my newish halyard.
Please help!!
Thanks!
PostPosted: Wed Mar 20, 2019 9:13 am
I don’t know the details on the pin (though I would guess it’s 1/4-20 thread, you could easily verify by checking the threads with a screw).
Anyway, worst case scenario, I think you could carefully drill out the threads on the shackle and then just use a standard clevis pin with split ring or a quick-pin. That would at least allow you to salvage the halyard if you can’t find the right threaded pin.
PostPosted: Wed Mar 20, 2019 3:19 pm
10670000 SHACKLE, HALYARD
US$ 12.59
You could take the pin from a new shackle as an option.
PostPosted: Thu Mar 21, 2019 5:14 pm
I got a new shackle and filed off the pin nubs.
Any thoughts on putting the 'captive' back in the pin? Would solder stick to the pin?
PostPosted: Fri Mar 22, 2019 8:47 am
Worth a try!
PostPosted: Sat Mar 23, 2019 1:05 pm
How about a spot of 5200 or JB weld?
PostPosted: Sun Mar 24, 2019 1:14 pm
The pin is most likely stainless steel.
You could try silver solder with a flux. If you know anyone who can tig weld they could easily put a couple dots of weld on the pin.
