It is currently Sun Aug 02, 2026 1:52 pm
PostPosted: Fri Mar 30, 2007 1:21 pm
I have an older hobie without adjustable upper housings. Can I replace just the upper housings with the newer style or do I have to replace the lower housings at the same time?
 Post subject: Adjustable uppers.
PostPosted: Fri Mar 30, 2007 2:12 pm
You can do that.
The upper casting adjustment will allow you to get a tight fit (forward rake) into the lower casting. If you want the rake a little aft, you will have to shim the lower housing. Maybe a bit of durable selant like 3M 5200. Set the rake then squirt some sealand into the lower part of the casting where the rudder rests. Place a small mylar or saran wrap cover over the sealant and settle the rudder into it at the proper rake. Then, when the material is hard... set the upper adjustment to hold the blade there.
