It is currently Sun Aug 02, 2026 10:05 pm
PostPosted: Sat Mar 16, 2019 4:23 pm
Does anyone know a part number or pin diameter for a quick-pin that will work in the small holes in a Hobie 16 6:1 main downhaul? I attach/detach the downhaul via the ring-ding on the part that is screwed in the mast track. There is no room for fingers and it is a 'you know what' to install/remove.
PostPosted: Sun Mar 17, 2019 6:38 am
Totally agree....after first time rigging with the regular clevis/ring ding, I installed a quick pin. Diameter is 3/16".....same as main traveler deck plate....pretty sure the part in the track IS a main traveler deck plate. Not sure about length.
Jerome Vaughan
Hobie 16
PostPosted: Wed Mar 27, 2019 7:27 pm
Jerome's right, it's the same as main traveler deck plate, so you could use one of these... https://www.murrays.com/product/18-3m075/ (I have no affiliation with Murray's, just easy to link to)
Bradley M. Davis - Hobie High Life YouTube Videos
2012 H16 (with 2018 Cayman Main) #115139
