It is currently Sun Aug 02, 2026 5:40 pm
PostPosted: Thu Aug 22, 2013 4:39 am
Hi Folks,
I am in deep trouble so though I should share a few words of warning. 'Do not use the wife's frying pan!' :shock:
But at least sails are dry and my couch is comfortable :wink:
Please find pictures of sail and boom trailer storage tube and hastily made fiberglass end caps.
The tubes are 1 foot internal diameter and 10 feet long. I have two of them mounted to the trailer (don't have picture of this at this time)
The end caps are currently unpainted so intend to get to this shortly.
-SRG
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
Hobie 16 1990 (storm damaged)
Hobie 16 1996 (my latest)
PostPosted: Fri Jun 14, 2019 9:23 am
Where do you find the corrugated plastic? I had considered this as well, but I don't know where to look to purchase it.
How much did that setup cost to build?
PostPosted: Thu Jun 20, 2019 1:00 am
Hi not sure were you are located but I am UK based.
A quick search provided https://store.jdpipes.co.uk/300mm-perf-twinwall-6m/
Its called 300MM PERFORATED TWINWALL PIPE also available unperforated.
If I recall correctly I cut the 6mtr length in half to make two 3mtr storage boxes and strapped them with metal strapping but a ratchet strap worked just fine as a temporary solution.
