It is currently Sun Aug 02, 2026 10:29 am
 Post subject: front boom cap removal
PostPosted: Mon Sep 16, 2019 12:55 am
Hi, are there any secrets for removing the front boom cap from an old h16 boom that would have never been removed? I have a seized gooseneck pin that in now broken off in the cap.
PostPosted: Mon Sep 16, 2019 9:07 am
Mallet and a big blade screw driver. Going around the cap to try and knock it out evenly.
PostPosted: Mon Sep 16, 2019 9:19 am
Also make sure that when you remove the rivets, all material from the rivet shank has been cleared from the hole. Even a small sliver of stainless steel left in the hole can cause the cap to bind, making removal impossible.
Clamp the boom in a bench vice or affix it to something solid before attempting to knock the cap out. Otherwise when you hit the cap with a mallet, you’ll just move the whole boom.
