It is currently Mon Aug 03, 2026 1:51 am
 Post subject: Ronstan jib cars
PostPosted: Sun May 13, 2007 10:29 am
I am upgrading my jib sytem to new Ronstan jib cars. Does anyone have a recommendation on how to keep the pin up on these so I can adjust them with my barberhauler lines? I'd hate to have to grind the pins off these brand new parts :(
PostPosted: Sun May 13, 2007 11:00 am
I tied the adjustment line around the pin. Pull the pin up and tie it tightly. I only had a problem a couple of times in two years set up like this. You might be able to put a zip-tie around the pin to hold it up also. That would pretty much guarantee the pin wouldn't go back down.
PostPosted: Mon May 14, 2007 8:45 am
Authorized Hobie Dealer
yea the line should keep the pin up no problem. I do like the idea of the zip tie!
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Mon May 21, 2007 5:19 am
I did the same upgrade and what the instructions say is to tie a figure 8 know around the pin. I did it like that and it hold the pin up no problem.
You are gonna love the new set up. It makes alot of difference! :D
It's such a fine line between stupid and clever.
86 H16
