It is currently Sun Aug 02, 2026 2:02 am
 Post subject: Hobie 16 questions
PostPosted: Wed Feb 17, 2021 4:36 am
I have a new Hobie 16 and have a few qus:
1. The traveller car comes out of the integral track at one end..what is supposed to stop that? The seller said he used a knot on the mainsheet but I think there should be a stop somewhere in the track.
2. I have bought 3 x swivel clam cleats for the main and jib but they have flat bases. Can I reuse the old ones and will self tappers do to secure them?
3. There's a twist toggle on the end of one side stay but not the other...are they that important?
4. What diameter is the tiller rob?
Any help appreciated.
Cheers
 Post subject: Re: Hobie 16 questions
PostPosted: Wed Feb 17, 2021 9:38 am
Use a knot to be sure the car does not smack the corner casting and will keep it in the track, but there is a plate that is supposed to be riveted there.
https://s3-us-west-1.amazonaws.com/media.hobie.com/item_attachments/11810011z52.pdf
You should be able to re-use the mounting plates. If corrosion is an issue, you can move a bit to one side.
This is the mounting plate Image
Twist toggles take bending load off the anchor pin (a universal joint). Yes, important.
Tiller rob?
cron
