It is currently Sun Aug 02, 2026 5:34 pm
 Post subject: Resetting Comp Tip
PostPosted: Tue May 29, 2007 1:18 pm
I have a comp tip that has some definate wobble in it. It has the bolts on the side (older style) bit is a newer comp tip that I had to shorten at the top.
What is the best way to get the tip resealed and firm in the aluminum mast?
It's such a fine line between stupid and clever.
86 H16
PostPosted: Tue May 29, 2007 1:45 pm
Epoxy.
PostPosted: Tue May 29, 2007 1:56 pm
I take it you mean to pull it apart first, epoxy then reset..
86 H16
PostPosted: Tue May 29, 2007 1:58 pm
That's what he meant. We use West Systems when Hobie forgets to send us their stuff.
Brian C.
PostPosted: Tue May 29, 2007 2:22 pm
Sounds good, should'nt be hard to get apart with the flexing its already doing.
86 H16
PostPosted: Tue May 29, 2007 5:04 pm
A torch with MAPP gas will help loosen up the epoxy.
PostPosted: Tue May 29, 2007 7:13 pm
All of those guys above are right. Do exactly what they said, and add an adhesive filler to the epoxy so it has some bulk when you reset the comptip. I find that with West Systems the 404 filler works well. With Fiberglass Hawaii use the glass bubbles. Mix it like a thin milkshake. I find that with straight epo it runs, and if there is a big gap it won't bond well. Also with the torch, epoxy will start to come loose at around 140F, the comptip is a heat cured epoxy (I think it cures around 200F), but be careful to not melt the comptip. Have fun!
Sail Revolution
Join us on our new FB Page!
PostPosted: Tue May 29, 2007 7:48 pm
What Jeremy said - filler and all. But we say "Mix it till it looks like warm peanut butter." :wink:
Brian C
PostPosted: Tue May 29, 2007 8:06 pm
The epoxy is not the seal. The seal is epoxy (A&B) foam poured in after the mast is together. If you haven't worked with epoxy foam, it is heat, humidity, and mixing time sensitive, and can/will make a mess. Done right it will seal the lower portion of the mast well.
