It is currently Sun Aug 02, 2026 5:34 pm
 Post subject: main beam
PostPosted: Thu May 31, 2007 3:54 am
hi to all
just one question...
how much i must thight the dolphin striker?
can u post me the measure beetween the front fusion where the ds is bolted?
thanx a lot
max
PostPosted: Thu May 31, 2007 4:11 am
The dolphin striker should be tightened until it sounds like "thrummmm" when you hit it with your hand.
If it goes "clunk", it's too loose.
There no real measurement to be made. You tighten it until it is . . tight.
I'm not sure what you mean by "the front fusion"
PostPosted: Thu May 31, 2007 6:26 am
i mean the fron corner....
to tight mine i have measured the distance between the front corner on mine and over another h16 more new, were the dolphin striker enter and tight mine to achieve about the same distance
