It is currently Sat Aug 01, 2026 9:04 pm
 Post subject: comp tip for dent mast
PostPosted: Fri Sep 10, 2021 8:34 am
Hi .. just acquire a Hobie16 and the previous owner made a dent/bent in the bottom section of the mast ... i have a comp tip and my plan was to cut the bottom of the mast to install the tip there and switch all the hardware on the mast around ....
i'm a crazy ?? should work right ??
PostPosted: Fri Sep 10, 2021 4:39 pm
That could work.
PostPosted: Fri Nov 26, 2021 6:28 am
lol
Call me crazy too, but I agree with Matt. I suppose if all the external hardware and the internal foam plugs were replaced, don't see why not?
A bit of work... go for it
Image Image
'89 H14 'Jaws'
'85 H16
PostPosted: Sat Jun 04, 2022 1:13 pm
Comp Tip on the bottom of the mast? Don't know how you would get the various hardware pieces to mount. How far up it the dent? Have you thought about straightening out the dent? That would probably be much stronger than a composite section at the bottom of the mast, which is under the most stress.
PostPosted: Thu Jun 16, 2022 9:36 am
Where are you located? If you can drive to Southern California, I have a spare mast off a 1982 H16 that I will give to you.
1977 Super Sunfish (sold)
1979 Hobie (sold)
2008 Hobie 16 (sold)
2023 Hobie 16
John
