It is currently Sun Aug 02, 2026 4:50 am
PostPosted: Wed Jul 22, 2020 5:56 am
I built a righting pole for my Hobie 16. I know this has been discussed many times before but I thought I may help someone out refreshing the topic.
https://youtu.be/DPGWqVNe4k0
I got my material build list from another post on here but I can't seem to locate it.
1 1/2" aluminum tube or wood dowel roughly 7'6" (width of the pylons)
4 - 2x4's cut at 8"
4 - 1/2" plywood cut 8x10"
Stainless bolts to secure pole to 2x4 blocks
1 1/2" screws to screw plywood to 2x4's
Contact cement and outdoor carpet for traction
Instead of using 1 1/2" aluminum tube I used a 1 1/2" wooden dowel and fiber-glassed over it. I tried to get away with 1/4" rope. but found 1/2" rope was required or the stretch was too great.
I've been going solo and there aren't many boats around for assistance. I have SeaTow but they can take up to 2-3 hours. Also I didn't feel confident in the righting bag system since it seems like there is a technique required to get it to work.
This system seems to get the job done and give me that extra leverage. Deployment is easy, un-bungie both ends of the stick. Toss the lines over the top hull each side of the pylon and secure with carabiner clips. Place the bottom of the righting pole into the groove on the bottom the hull. Walk out slowly and flip it back over.
PostPosted: Wed Jul 22, 2020 8:16 am
Awesome thanks! Can you share pics of how you attach and deploy?
PostPosted: Wed Jul 22, 2020 9:25 am
Here is the video I based mine off of. He’s got a hobie 18 so instead of placing the base ontop of the daggerboard I put mine into the lip of the hull.
https://youtu.be/jTRS5pTZGV4
For storage and easy deployment I have it bungee corded to the front of the trampoline. Seems to stay high and dry even when flying a hull
PostPosted: Wed Jul 22, 2020 9:34 am
Nice, thanks for sharing. I am trying to figure out how to make a combo righting pole and oar for when the wind is too much...or too little. I think it comes down to a design like yours with thinner, stronger materials. Or a detachable paddle section.
PostPosted: Wed Jul 22, 2020 10:41 am
Yeah I think. you could make 1 end a paddle instead of a box like I did. The paddle end could easily fit under the hull lip and have the same effect.
Here is a pic of me flying the hull and you can see how I mounted it.
https://photos.app.goo.gl/UnZgsuQBwpxt8JtNA
PostPosted: Thu Jul 23, 2020 5:27 am
Awesome that pic helps a lot. Nice boat!
PostPosted: Sun Jul 26, 2020 5:05 am
When Dave, guy in video with the 18, and I came up with the original righting stick, we used the aluminum pole, worried that a wooden one could snap. But a lot of people are now carrying 2x4's. This one was a 2x6 cut down to give the sailor more width to walk up, sprayed with traction grip on one side.
Buxton
18' T16 Silent Lightning (16' T2 Hybrid)
11' H16 White Lightning
79' H16 Green Lightning
PostPosted: Sun Apr 17, 2022 7:13 pm
I’ve put righting pole together using a combination of what’s in this thread, I’ve also added an extension piece.
Seems to work well. Check it out
PostPosted: Tue Apr 19, 2022 2:58 am
Looks good. On the water you will want to be closer to the front cross bar, that's the center point for righting the boat. Where you are at now, the bows will lift first and the boat will start to rotate on the water as it comes up and you will most likely fall off the stick.
You'll love it once you get it sorted out.
Buxton
PostPosted: Tue Apr 19, 2022 3:36 am
No worries, thanks for the advice.
PostPosted: Thu Aug 18, 2022 12:21 pm
Recommend making the righting pole longer. You can fasten it to bottom of tramp on either side and let extra hang out front.
PostPosted: Tue Feb 14, 2023 2:59 am
Apologies, not sure what happened but I attached the incorrect link.
Here is my version of a righting pole
https://youtu.be/c-sKvuICJ0I
PostPosted: Tue Feb 14, 2023 3:02 am
OMG I can’t get it right.
Let’s try again
