It is currently Sun Aug 02, 2026 12:41 am
PostPosted: Fri Nov 10, 2023 7:39 pm
First to clear up what I'm NOT asking about.
We have adjusted our rudder stock, rudder blade, gudgeon bushings and CAM setting so that there is no movement in the rudder blade either fore and aft or sideways.
But there is still play in the tiller (NOT the cross bar, AKA camrod, between the 2 rudder tillers). With the rudder stock held firmly and the blade locked down in sailing position, cam locked, with cam adjustment set as far forward as possible, and the tiller bolt firmly tightened - so it will not drop down of its own accord (which is too tight - set like this to eliminate that as the issue) - the tiller has side to side slop.
How can this tiller slop be eliminated?
Built 2009.
Thank you
Rob
PostPosted: Sat Nov 11, 2023 4:47 pm
Sounds like you’re talking about slop between the tiller arm (aluminum tube) and the upper rudder casting.
Over time, the rivets that hold the tiller arm into the casting can loosen up, so you can simply drill out the rivets and re-rivet the arm into the casting. While you have the arm out, slip some shim material between the tube and the casting to tighten the fit. You can use a plastic soda bottle or a beer/soda can as shim material. Try to line up the shim with the rivet hole so that the shim won’t move around (you will need to drill a 3/16” hole through the shim before re-riveting).
PostPosted: Sat Nov 11, 2023 5:17 pm
Excuse my ignorance. Now I know what the part is called. The slop is between the upper and lower casting.
PostPosted: Sun Nov 12, 2023 7:25 am
Despite your description it's still not clear to me what part is moving relative to what other part. You're the one that's there; what two parts are not tightly connected? It's extremely unlikely IMO that the tiller arms would be loose from the upper casting.
You have the rudders firmly mounted in the main casting, right? That's how it sounds.
Is the top casting loose on the rear hole of the rudder?
Is the tiller crossbar loose against the arm?
Is it the side-to-side play of the upper casting against the main casting in the area of the cam?
'00 H16 #104691
Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Sun Nov 12, 2023 8:52 am
Check for elongated holes for the rudder bolts through the rudders. If the holes are too large it can related to slop at this connection point. If the cam plate (in the upper casting) is pushed all the way forward, but does not keep the rudder tight forward in the lower casting... the upper castings hole can be filled and re-drilled to allow for a net fit for the bolt and some adjustability for the cam plate.
Take a look at a rudder rake FAQ: https://www.hobie.com/forums/viewtopic.php?f=18&t=467
PostPosted: Sun Nov 12, 2023 2:32 pm
it is the side-to-side play of the upper casting against the main casting in the area of the cam
The rudders are firmly mounted in the lower casting.
The upper casting is firmly bolted to the rudder blade.
There is no play in the rudder blade fore and aft. The cam Plate is as far forward as possible. Cam is firmly locked.
PostPosted: Sun Nov 12, 2023 2:36 pm
Made subject clearer
PostPosted: Mon Nov 13, 2023 10:16 am
The upper rudder bolt hole may be elongated or over sized. If the cam plate is maxed out (forward), re-drilling the upper hole, slightly more forward, would help add some adjustability. Plug the hole with thickened epoxy, set the plate more in the middle of the adjustment... then lock the upper casting into the cam and while holding the rudder forward, use the casting to locate the new hole position in the rudder... re-drill.
You can also add plastic bushings on the bolt (either side of the casting) to help tighten that up. This is a pretty common fix.
https://westcoastsailing.net/hobie-rudder-stiffening-kit/
https://media.hobie.com/item_attachments/136z52.pdf
PostPosted: Sun Mar 01, 2026 2:34 am
Matt's picture of the plastic bushings is what you need. I never bought those. I bought butter, cottage cheese, and sour cream so I could make those shims out of the lids. Plastic milk cartons, laundry detergent, and other HDPE materials are fine to use. The shims are 3 inches in diameter with at 5/8" hole (or whatever bolt size is) in the center.
Before you do anything, set up the boat on the trailer with the rudders down and locked. Now glance into the aluminum rudder casting to see the upper and lower bolts running through the rudder. The gap on each side between the rudder and casting will be different indicating you need more shims on one side than the other. In every case you will need at least one shim to protect the rudder from the rough aluminum casting. Once you know which side of the rudder needs more shims, get ready to pack as many shims in there as you can to fill up the gaps on each side of each rudder, top casting and bottom. It's a fiddly task to get them all in there. Somewhere I saw a suggestion to use tape to hold them together. If you get it all together and realize that you forgot to put at least one shim somewhere, you really, Really, REALLY should take it all apart and fix that detail.
The shims are 95% of the fix. As a final step in the process you can mold a custom bed for the rudder to fit into when it is down. Note that the rudder blade slams up against the aluminum casting when it lowers down. It can fit kind of randomly, but you can bed it down using black RTV (silicone). It's not hard. First mark the rudder to know where it sticks out of the casting on the bottom. Then wrap from your mark to the top of the rudder with plastic cooking wrap and tape that on. Raise the rudder and unload a bunch of the black RTV into the lower rudder casting where the rudder will land. After you get a good glop of RTV in there, gently lower the rudder and lock it down. Let that sit like that overnight before raising the rudder. Peel off the tape and Saran Wrap and you are ready to go. When the rudder is down, it cannot move and neither can the upper casting.
It's a lot of fun to sail a Hobie, but it's a lot more fun to sail a fun Hobie.
