It is currently Sat Aug 01, 2026 7:46 pm
PostPosted: Wed Jul 17, 2024 11:42 am
I am just getting into hobie 16 sailing and I'm ready to buy a trapeze harness. It seems like I'm limited to buying online by my location so trying on is an issue. I'm also 6'7' and fairly skinny. It seems most of the full harnesses would not be long enough for my torso or too wide in the XXXL or whatever and I'd be worried that the half harnesses or buckets wouldn't provide me enough backsupport as my back is so long. Any other tall sailors out there? What are you using?
Thanks!
-Thalweg
PostPosted: Thu Jul 18, 2024 2:03 am
Can't help with the being tall part, but here are some opinions otherwise...
The most important thing is for the harness to fit snugly around your waist, hips, and legs. You do not want to just hang in it...it needs to be like a part of you. While most have a wide range of adjustment, if it's still loose when you tighten it all the way, you will be miserable.
Sailors who do a lot of longer distances where you're likely to be on the wire for long periods seem to prefer the full harnesses. I do little of that, and even the best harnesses aren't exactly comfortable (somewhat binding, hot in summer, etc.), so for me less is better.
I suppose that, if I had a bad back, I'd be more inclined toward a full harness. If that were the case, though, I probably wouldn't be doing something for fun that involves moving a 320 lb. boat around!
Other than that, it's mostly personal preference. If you can meet up with other catsailors in your area, perhaps you could try on some of their harnesses (and test them hanging from the trapeze).
Jerome Vaughan
Hobie 16
PostPosted: Sun Jul 06, 2025 8:49 am
Just curious if you ever found a harness that suited your needs? I’m 6’4” and in a similar situation. Looking for my first harness.
PostPosted: Sun Jul 06, 2025 8:52 am
cron
