It is currently Sun Aug 02, 2026 7:58 pm
 Post subject: Year of Sail by Number
PostPosted: Tue Jul 17, 2007 7:20 pm
I picked up a used set of H16 sails with a # of 52014.. This set is solid yellow and is a thicker dacron than my 81 Boomer main..
Does anyone know what year this sail was possibly produced?
Not sure if there is a sail number by year chart or something.
It's such a fine line between stupid and clever.
86 H16
PostPosted: Wed Jul 18, 2007 2:55 am
If it's a Hobie sail, then it's about 1980.
PostPosted: Wed Jul 18, 2007 8:10 am
Matt might have done this but if you are needing that research in the future you might take a look at old regatta results. The highest number in those results was probably built in the same year, maybe year before, as the regatta, if it is a 16.
Dan
PostPosted: Wed Jul 18, 2007 8:31 am
Unfortunately, the Hotline stopped publishing sail numbers in regatta results sometime in the mid-70's.
There was also an explosion of numbers in the late 70's / early 80's.
My 1978 H-16 was 33556.
My '83 sail was 74722. That's over 8,000 sails a year.
PostPosted: Wed Jul 18, 2007 9:11 am
I've found the sail-pattern chart in the Hotline (Mr. "Hotline Bounds", do you know the right issue?) helps identify years, as long as it wasn't a custom color.
Tim
http://www.hobiefleet72.org
PostPosted: Wed Jul 18, 2007 12:32 pm
I found the Hotline with the sail colors by year. See link below
http://www.hobiecat.com/hobieclass/eHCA ... 4_2006.pdf
PostPosted: Wed Jul 18, 2007 12:42 pm
Ive got the sail pattern hotline issue also.. From that, its possible that its a 77 or a 79 since it does show the solid yellow and some other solid colors listed as Nationals (not that this is a old Nationals sail I wouldnt think)
86 H16
PostPosted: Thu Jul 19, 2007 6:05 am
'79 is the best guess. Most '81 sails were upper 5XXXX & lower 6XXXX numbers
HCANA Class Member
PostPosted: Thu Jul 19, 2007 6:14 am
Another tip may be the font of the numbers.
Didn't all sails change to the current Souvenir Bold in 1980?
HCANA Class Member
