It is currently Mon Aug 03, 2026 12:38 am
 Post subject: Hull weights?
PostPosted: Tue Aug 21, 2007 8:41 pm
Hi, I have recently purchased 2 well used 16's to create 1 decent one.
I have both entirely dismantled at this time and would like to use the best parts from each..
I have noticed that there is a difference in Hull weight. I would like to use the lightest 2 of the four, does anyone see a problem?
Thanks, Chris
PostPosted: Tue Aug 21, 2007 9:18 pm
Just as long as they are not the soft ones. :)
PostPosted: Wed Aug 22, 2007 7:23 am
or both the port hull :?
Sail Like you Have a Pair
Bluish gray 73 - 83 H16
Super Nice Yellow 84 H18
PostPosted: Wed Aug 22, 2007 8:30 am
Forgive me in advance for my lack of understanding.
Are there different hull stiffness?
How do I tell?
PostPosted: Wed Aug 22, 2007 8:38 am
How do I tell?
Are there different hull stiffness? YES Kind of. If your hulls are delaminated they will be what is referred to as soft. You want to check the hulls (mainly the decks but also the sides) for soft spots. First, you can find problems by pressing (not with all of your weight) on the hulls, if there is any give or crackling, you may have a problem.
You should be able to tell a soft spot fairly easily.
Good luck
PostPosted: Wed Aug 22, 2007 10:31 am
Forgive me for stating the obvious, and Banzilla touched on this, but the hulls are asymetrical. There are port hulls and starboard hulls. I would assume you would use the best one of the port hulls and the best one of the starboard hulls.
