It is currently Mon Aug 03, 2026 12:38 am
PostPosted: Wed Sep 05, 2007 6:13 pm
I have been shopping for an H16 for about 6 weeks now and I find it surprising that I have not seen any (or at least very few) H16's for sale from the late 80's or early 90's.
What happened to the boats that were built from about 87 to 96? Either Hobie didn't build very many or nobody sells them? There are plenty of used H16's from the 70's and early 80's.
Just curious.
Michael
Michael
'86 H16 #91487
PostPosted: Wed Sep 05, 2007 8:32 pm
I have found the same thing.. nobody wants to get rid of em' or they are sitting in the yard and they think that nobody want's them.. I would recomend finding an older one and put your personal touches into it. Just make sure all the rigging is there the hulls arent beat up or have soft spots and if it is a 16' and has portholes make sure the decks are not soft, which signifies delam, my old 16' had that prob. Ask youself, is the tramp decent? does all the swaging on the standing rigging look good and not coroded? has it been trailered with the rudders on? if so are the casting's wore out? does it have adjustable upper rudder castings? for a lack of the term are the mounting points for the bridle wires wore out and oblonged? are the shroud mounting points beat up? the list can go on and on but basically just check it out good and make sure you can sail it at least three to four times before winter to make a list of squaks. my 2 cents. George
PostPosted: Thu Sep 06, 2007 3:41 am
There's a real simple answer to this - there aren't nearly as many late '80's and early '90's boats out there.
The peak production years were 1977 - 1983, when an average of about 10,000 boats a year were being produced.
By 1995, that number had dropped to under 1,000 a year.
PostPosted: Thu Sep 06, 2007 6:19 am
Thanks! I knew there had to be a reason for it!
George, I'll probably end up taking your advice and buying an older one and giving it my personalize touch!
Michael
'86 H16 #91487
PostPosted: Thu Sep 06, 2007 6:59 am
Michael, if you're interested and somewhat close to Oklahoma City I know of a local sailor selling his '88 for a very reasonable price. Probably needs a newer main, but the hulls are tight and sails very well. Contact me @ jmork1 (at) cox (dot) net.
