It is currently Sun Aug 02, 2026 11:35 pm
PostPosted: Mon Oct 01, 2007 12:24 pm
Hi,, I need to order a set of jib and main battens for my H16. I have gone into several dealer web sites and they state that H16 battens have to be cut to lenght, since they are made from lightly longer batten stock. Race legal and all they stated the battens are Hobie battens not aftermarket or generic, and have the same part # as in the hobie catalog.
Is this true?
I inquired and they dont seem to know to what exact lenght they sould be cut.
Anyone?
PostPosted: Mon Oct 01, 2007 12:32 pm
Authorized Hobie Dealer
You could buy a h16 jib batten set in the past, I just noticed they no longer have a part number next to it. You would then need to order the proper length and cut them.
The stock lengths are:
#4 30"
#3 45 3/4"
#2 57 7/8"
#1 68 7/8"
As everyone knows these are to long, you would need to custom fit them for your jib.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Mon Oct 01, 2007 12:37 pm
That was the case for me. I ordered a replacement set of jib battens and cut them myself. The universal battens are located towards the front of the parts catalog. I assume that is the standard stock length.
The correct jib batten lengths are shown in the back of the catalog in the H-16 specific area next to the rest of the jib rigging hardware.
I would think that the main batten lengths are in the same place.
1984 H16 - #80541
PostPosted: Mon Oct 01, 2007 12:45 pm
Hobie used to make battens for each model in different colors. The 14's battens were green; the 16's, blue; the 17's, black; the 18's were yellow. There was no difference between them other than the color.
Each batten was cut to a specific length for each model's sail. That makes for a lot of different lengths (over 30).
Someone (probably Matt M.) had a brilliant idea - make one color batten and standardize the sizes down to about 8. Most of us trim our battens down to fit the sail anyway, so this made things much simpler for Hobie Cat.
PostPosted: Mon Oct 01, 2007 1:58 pm
Brad, Now Im more confused... One of the dealers I sent a request to was Sun Jammers...
Jib batten set appears in your web page:
20400001 jib batten set
price: $74.35
So if they are no longer available in a set how would I order them?
thanks!
PostPosted: Mon Oct 01, 2007 5:03 pm
thanks for letting me know, they were available last year from Hobie, I will double check and make sure they are no longer available and if there not I will take them off the site.
things change fast!
Brad Stephens
PostPosted: Tue Oct 02, 2007 9:11 am
I just got conformation from the parts department at Hobie, that is still a valid part number, in stock at Hobie Cat.
Brad Stephens
