It is currently Mon Aug 03, 2026 2:45 am
 Post subject: Jib battens?
PostPosted: Thu Mar 06, 2008 7:18 pm
Newby question! I bought super jib set battens. How far should they stick out past the jib? They stick out 4" Past the jib and it seams like that will be too far. How would the jib get around the mast? Do I need to trim them? I also don't know how to tie them with only one hole and no notch. Please help.
I wish winter was not so long in Sask. Canada. It's hard to sail on ice! 1984 16' hobie cat Sail# 84848
PostPosted: Thu Mar 06, 2008 7:32 pm
Hey wow first Hobie sailor from Saskatchewan I have seen post here, besides myself. Where are you from and where do you sail?? As far as the battens are concerned you should cut them as short as possible to keep them from hanging up when you tack. I left mine out about 1" when I had then tensioned how I wanted them, that still leaves you some adjustment later if you need.
PostPosted: Thu Mar 06, 2008 7:56 pm
I'm from Fiske. About 11/2 hour west of saskatoon. I have always wanted a hobie, but have no clue how to sail one. I wish I could find a local to help walk me through it. Do you know of any 16' around that could help? I would like to sail at the landing and black strap. Were do you sail?
PostPosted: Fri Mar 07, 2008 8:13 pm
Trim them so they stick out about one inch after the batten is tensioned. Release after every sail so the sail doesn't stretch.
PostPosted: Fri Mar 07, 2008 9:12 pm
Burley, I could help you out this summer if you want, email me and we can discuss the details [email protected]
