It is currently Mon Aug 03, 2026 6:17 am
PostPosted: Sat May 31, 2008 6:48 pm
I replaced a bent mast today with a new(used) mast... my old mast tang had 2 holes drilled in it one for the shrouds and one for the trapeze. The new mast tang ony has one hole. so do i put all the 6 wires, 2 shroud and 4 trapeze wire on the same shackle? It seems like alot of stuff on the same shackle?
PostPosted: Sat May 31, 2008 7:52 pm
Sounds like it has the wrong tang. It might be a tang for an old boom vang. Take it off and put the correct one from your old mast or buy a new one from Hobie.
Alan
'86 H16, Sail #89057
PostPosted: Sat May 31, 2008 8:07 pm
Sometime in the late 70's the mast tang was updated to the current configuration.
The original may be used but you'll need either an over-sized shackle, or alternatively, hang one additional shackle on each side for the trapeze wires only.
A 4" angle grinder makes rivet heads disappear quick, if you want to install the newer tang.
Sheet In...Max Out
www.fleet297.org
PostPosted: Sat May 31, 2008 8:49 pm
The same thing happened to me when I bought a used mast after mine got bent, my old mast had 2 holes in the tang and the new one had only one hole. I used one large shackle for the shrouds and another for the trapeeze, never had any problems. I will probably put my 2 hole mast tang on it when I get the time or feel the need.
John G.
PostPosted: Sun Jun 01, 2008 4:21 am
Thanks for the quick replies guys. It just seems like alot to ask of one single shackle but I'll give it a try and go with the 3 shackle option.
PostPosted: Sun Jun 01, 2008 10:54 am
Like those guys said, put them all on one shackle. If you have the single hole tang, inspect it for cracks often.
Sail Revolution
Join us on our new FB Page!
PostPosted: Sun Jun 01, 2008 5:51 pm
Five wires go on the bow of the shackle (crew trap / shroud / forestay / shroud / crew trap).
Skipper's trap goes on the pin of the shackle with the tang in the middle.
Kind of like this (from a 14 w/trapeze):
PostPosted: Wed Jun 04, 2008 8:49 am
Thanks mbounds for taking the time to post the picture it is really helpful.
PostPosted: Wed Jun 04, 2008 6:47 pm
I agree. Drill the rivets out and put the tang off your bent mast on.
