It is currently Mon Aug 03, 2026 2:45 am
 Post subject: Jib traveler car blocks
PostPosted: Mon Jun 09, 2008 7:09 pm
Is there a way to replace just the pulley in the block? Mine are falling apart and I don't want to spend the money to replace them till I decide what I want to upgrade on the system.
PostPosted: Mon Jun 09, 2008 7:22 pm
are you talking about the Seaway kind that are on the stand up spring?
~vinny
PostPosted: Tue Jun 10, 2008 7:27 am
Yes they are
PostPosted: Wed Jun 11, 2008 6:12 am
The old seaways can be had for about $10 each used.
PostPosted: Wed Jun 11, 2008 6:50 am
On those old cars, we drill out the rivet that holds the old sheave. Then we replace it with a Harken 160 ball bearing sheave. We use a 1/4" diameter clevis pin and lock ring or cotter pin to hold it in.
Works good.
Brian C
PostPosted: Wed Jun 11, 2008 12:44 pm
Or like Tri X Troll said, you can have mine for $10 a pop
~vinny
PostPosted: Sat Jun 28, 2008 8:57 pm
I bought the harken 160's drilled out the old ones worked like a charm thanks
PostPosted: Mon Jun 30, 2008 6:57 am
Is there any way to replace the sheave at the base of the mast for the jib halyard? I don't think I have ever seen an older boat where this one is not crumbling.
PostPosted: Mon Jun 30, 2008 7:44 pm
It just so happens that you can do it the same way with the same harken 160 and a 1/4" clevis. thats what I did to mine it worked fine. You will have to remove the rivets but you will have to do that even if you buy a new one the harken is much better
