It is currently Sun Aug 02, 2026 7:08 pm
 Post subject: Perfect drive leash Mod
PostPosted: Wed Oct 16, 2019 7:19 pm
Hello all. New here. Just got a 2020 Outback and figured out a good way to mount the mirage drive leash so I thought I would share. What I did was swap the fitting under the seat that holds the bungee that is supposed to secure your drive with the fins up with the fitting at the bow that holds the bungee meant to hold down the hull hatch. Super simple. The fitting under the seat has a pad eye, so swapping gives you the perfect spot to attach your drive leash, which I made myself. I have no use for the pad eye under the seat and the original function of that bungee still works as intended since you can still clip to the other side that still has the pad eye. I took some pics of the finished product, hope they help explain it.
