It is currently Mon Jun 22, 2026 2:55 am
PostPosted: Wed May 13, 2020 5:03 pm
Hello all- long time PA and Outback owner here. My PA is 6 yrs old and the drive is as good as new. I also have a 2019 Outback that is about a year old. 5 trips ago I noticed the drive was squeaking. I did some research and couldn’t find a clear response on whether or not the needle bearings should be greased or oiled. I recently took the drive apart and cleaned it. Then I greased all 7 needle bearings casings with high quality marine grease. Next trip out it still squeaks. Any ideas are appreciated.
PostPosted: Thu May 14, 2020 4:41 am
I expect adjusting the cable tensions may fix the problem. At a guess I would say they just slightly too tight.
PostPosted: Thu May 14, 2020 10:16 am
Welcome to the forum!
If you haven't already you might lubricate the areas pointed out in this video. I would bet it's something in the drive that isn't adjusted properly or not lubricated.
https://www.youtube.com/watch?v=CA2tVDsNBG0
PostPosted: Thu May 14, 2020 11:49 am
Good tips on that video. Once I started lubing in the prescribed areas my squeaky drive became silent.
~JOE~
PostPosted: Thu May 14, 2020 3:58 pm
That's one of the first things I did. No luck. I first tried a thin super lube oil that works great on machinery on decks of ships. No improvement. I then tried a thicker marine oil. No improvement. I then disassembled, cleaned, and greased all needle bearing sections. No improvement. Gonna try the trial and error cable tension adjustments in the next day or two.
PostPosted: Thu May 21, 2020 3:33 pm
Three trips later and over 24 quarter turn adjustments (one at time) to loosen and tighten all 3 cables it still squeaks. I think I have narrowed it down the drums and not the sprockets or idler pulley. Anybody got any other ideas?
PostPosted: Thu May 21, 2020 4:11 pm
Maybe a video? Hard to imagine the drums causing this. Basic GT bearings.
PostPosted: Fri May 22, 2020 9:42 am
Rich from Fishaholic fishing on youtube is squeaking too.
PostPosted: Sun May 24, 2020 2:57 pm
I will make a video of mine next trip out. It will be posted on my youtube page here: https://www.youtube.com/channel/UCALav7 ... Mw8Dnu4syQ
I looked at fishaholic's page and couldn't find a vid where he mentions a squeaky drive. Do you know which one it is?
PostPosted: Wed May 27, 2020 12:17 pm
Could be this https://www.hobie.com/forums/viewtopic.php?f=11&t=66595
PostPosted: Fri Jun 05, 2020 3:49 pm
Update: Made 2 trips this week.
First trip: drive squeaked for about 2 minutes then stopped making noise for the next 3 miles. No adjustments were made since last trip so I don't understand it. I did make a 30 second video of it but did not upload it. I can post it on youtube if anyone is interested just let me know.
Second trip: drive also squeaked for about 2 minutes then stopped for 4 miles. Again no adjustment have been made. Kinda strange but I can live with that.
Thanks Swfinatic for your suggestion. After I cleaned and put grease in my drive, I had already set the tension as Mr. Miller has stated in his post.
PostPosted: Tue Jun 23, 2020 12:18 pm
https://www.youtube.com/watch?v=_RuVmGFhCAE
Around the 3:30 mark.
PostPosted: Tue Jun 23, 2020 1:09 pm
Thanks greenmeanie. Same sound mine was making. 2 trips ago it squeaked for about 20 strokes then stopped again.
