It is currently Wed Aug 19, 2026 6:43 am
PostPosted: Tue Jun 23, 2020 12:13 pm
At first I thought it was rain maybe getting in but I have cleaned the water out numerous times and it keeps coming back after I am done for the day.
Is it normal to have a puddle of water in it after and few hours on the water?
The first time I used it there was no water at all.
I haven't even had it that long with hardly any use but would hate for Salt Water to wreck the electronics.
PostPosted: Tue Jun 23, 2020 1:18 pm
Need more info. How much water is a puddle? Was the front hatch secured? Was the storage hatch sealed? What were the weather/surf conditions? I have a 2014 PA14 and have had several 2016 to 2018 Outbacks. They all got water at some point but not much- maybe a pint at the most. My 2019 Outback gets a little as well every now and then but still no more than a pint.
PostPosted: Tue Jun 23, 2020 4:48 pm
It is normal to get some moisture in the hull. If you live in a humid area and then seal the boat up and get into cool water you will get a fair amount of condensation inside the hull. The electronics should always be in dry bags. Anything you need to keep dry.
PostPosted: Tue Jun 23, 2020 7:02 pm
You can Delete this thread for now if you wish.
I checked over the YAK again today because it is so new it shouldn't leak lol and found the stock MID hatch screws where kind of loose. SO I tightened those and checked the back hatch I put in and those where still tight.
I wiped all the water out of the hull again and all I can think that happened is the two out of four times I found water in it was rain got in through the hatch and even tho I wiped it out maybe some was in the sides of the hull?
But when I got back home after using it tonight all was still dry which makes me happy.
I will keep and eye on it the next few trips just to make sure.
Thanks for the reply's.
PostPosted: Tue Jun 30, 2020 7:58 pm
Great advice. I found a little bit in mine after each trip(2 trips) right under the center hatch. Gasket was protruding out in the center and two screws were loose. All fixed now.
PostPosted: Wed Jul 01, 2020 5:05 pm
Glad you found it! I'll pass that on to the factory.
