It is currently Mon Jun 22, 2026 2:55 am
PostPosted: Fri Oct 02, 2020 9:34 am
I'm not sure what's going on here exactly (Outback 19) but this screw is loose and dropped down to where you can see it. I think it helps stabilize the rudder housing. I've trying to screw it back in but it doesn't seem to catch on anything. Any idea how to repair this?
Steve
PostPosted: Fri Oct 02, 2020 9:46 am
PostPosted: Fri Oct 02, 2020 10:58 am
Was able to fix it. The bolt had come loose from a lock nut inside the housing. The bolt wasn't catching because the nut was flipped sideways. The components were easy to take a part and fix.
