It is currently Thu Aug 13, 2026 2:41 pm
PostPosted: Sun Oct 18, 2020 1:58 pm
This was a mod I posted on the facebook group not too long ago and wanted to share here with fellow 2019-20 outbackers.
Not sure if this has been done already or not. But, I found a way to add aftermarket Ama brackets to attach to the side rails instead of drilling into hull like the oem version does.
Aftermarket ama hardware includes:
-aftermarket ama kit (metal tubes, floats, and brackets) and yakattack geartrac knob kit from amazon (Links below)
-2 inch long 1/4-20 socket head cap stainless steel screws & 1/2" long nylon spacers @ home depot
Installation on the outback is a bit tricky due to NON-PARALLEL tracks. What I ended up doing was attaching assembled bracket to each half of tube bar first. Keep the bracket halves tight but loose enough to rotate with some effort.
Then install and position each half on tracks. Once positioned, bring both ends of tubes together to snap lock. Once fully assembled, tighten knobs a bit to secure position but not too tight to rotate tube as a whole. Feels solid with rotation and location of tubes adjustable anywhere on the tracks and NO drilling into the hull.
NOTE: The nylon spacers would need to have the center holes drilled out with a larger drill bit to accommodate the 2" screws. Use pliers to hold the nylon spacers and drill slowly by hand with appropriate sized drill bit.
UPDATE: I've tested this kit out in the water yesterday and they hold up! They can be positioned anywhere along the tracks and can adjust twist tension to raise or lower the floats on command. Also removable when you get on land and no indication of stress on the plastic rails they're attached to. The added stability should help out in the choppy ocean when hauling crab pots from the side.
All bought on Amazon except for the 2" stainless steel screws and nylon standoffs.
Yakattack Geartrak hardware:
https://www.amazon.com/dp/B01KMHVMGG/ref=cm_sw_r_cp_apa_fab_4H.EFbC42VKWV?fbclid=IwAR2I8P5d1qaXlFCpXEj0m8TGlv2oijiTrnYNP_QkZSDYrW8LhHm2hBqCgkw
Dynwave outrigger hardware:
https://www.amazon.com/dp/B07W5HMS2B/ref=cm_sw_r_cp_apa_fab_NJ.EFbN33B5D9?fbclid=IwAR30JlqUuqNV8cHMl7Eyd0Cn7tPk2JREo25Aq5TMyG3QBulrhFHjgHSlIWU
Outrigger sidekick arms:
https://www.amazon.com/dp/B07NVK1YLM/ref=cm_sw_r_cp_apa_fab_RK.EFbZ5HBZK7?fbclid=IwAR3a39JS1QbwphWwEkLcC8l3WkSpewRNEEhhjGRGYp3fasFLdGG5YHp5m28
Kayak floats:
https://www.amazon.com/dp/B07PVBG3JV/ref=cm_sw_r_cp_apa_fab_GL.EFbMMBZVYC?fbclid=IwAR0ccb-KYBnpd19Cpc8yrTbs6_wLWnxl44MskRe2Xj_joRZCwbmtGaYiUD0
PostPosted: Thu Apr 01, 2021 1:07 pm
For some reason your pics aren't showing up for me.
The post reminds me from this great solution:
https://www.hobie.com/forums/viewtopic. ... 40&t=64053
