It is currently Wed Aug 12, 2026 2:38 pm
PostPosted: Thu Aug 19, 2021 9:59 am
What is the part number and size for the socket nut which holds the banjo bolt that keeps tension on the rod that holds the upper mesh of the Vantage seat?
Duncan
PostPosted: Thu Aug 19, 2021 2:29 pm
Are you referring to the lumbar support system? Photo maybe?
PostPosted: Thu Aug 19, 2021 3:53 pm
I replaced the mesh back. The two full length spring rods that holds the mesh on each side are attached to the back frame with banjo bolts and barrel-sleeve nuts, one on each side. When I removed the nut it was stripped, overtightened from the original assembly probably, and now won't hold. On the back of the seat there are two phillips screws. These are not really screws but the nuts I'm speaking of.
Duncan
PostPosted: Fri Aug 20, 2021 9:14 am
865090 BARREL SCREW
PostPosted: Fri Aug 20, 2021 9:52 am
That's it, thanks.
Duncan
PostPosted: Sat Aug 21, 2021 8:39 am
Matt, I'm having a hard time locating this part. I think no one stocks it because it is a non wear part. May I email you for some help?
Duncan
PostPosted: Tue Aug 24, 2021 4:44 pm
Any dealer can order this. They would not stock it.
PostPosted: Fri Aug 27, 2021 8:42 am
Thanks, I did find one.
Duncan
