It is currently Fri Aug 07, 2026 4:35 pm
 Post subject: See front bolts
PostPosted: Wed Jul 26, 2023 9:36 am
Good afternoon, I would like to know if it would be possible or if someone has done it, if possible in the screws at the height of the pedal board, those that are on both sides if it is possible to put a ring or hook for the large thermal bag, so that Go better subject, or what would be Hobie's approach to it?
Yesterday he went to remove them and I realized from the inside that they have some part of the rudder and the transducer that is attached to them.
I attach an image of the screws and an image of the ones you would like to attach.
A greeting and good fishing.
[img]C:\Users\Puerta101\Desktop[/img]
Hobie Outback Papaya 2021 with Lowrance Elite Fs 9"
The best for Fishing!!!
 Post subject: Re: See front bolts
PostPosted: Thu Jul 27, 2023 6:26 am
Your link appears to be to your computer and not usable by anyone else.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Jul 27, 2023 7:39 am
It would be to add these pieces on one of the sides at the height of the transducer and rudder rope clamp. It won't let me add the photo of the kayak where it appears. all the best
PostPosted: Fri Jul 28, 2023 6:34 am
I would think the answer to your question is a qualified yes, as long as the load on the pad eye won't strip/pullout the self tapping screws from
the plastic and the area behind the screws is clear of internal lines/hardware.
Assuming the area is clear, if you can install a machine screw with a flat washer and nylock nut, is far superior due to the mechanical strength gained and no worry about the screw pulling out of the hull plastic material.
Dr.SteelheadCatcher
Warrenton, OR
