It is currently Thu Aug 06, 2026 11:21 am
PostPosted: Mon Jun 10, 2024 8:15 am
Hi,
Yesterday, I detected a leak on one of the bolts that hold the front hatch bungee cord. Given this, I decided to remove the part, clean it, and apply silicone to seal the leak.
When I proceeded to remove the bolt, I noticed that it wasn't tight. The nut could turn freely when I turned the bolt with a screwdriver.
After removing, cleaning, and applying silicone, I retightened the bolt and nut to a "snug tight" level. However, after doing so, I started wondering if this was the correct tightness. Was the original looseness meant to accommodate thermal expansion, or was it a manufacturing oversight?
I would appreciate any input from you.
Thanks a lot.
PostPosted: Tue Jun 18, 2024 10:04 am
i just did this as well. same reasoning.
i snugged it down. it is a nyloc nut so it backing out isnt a concern. i didnt gorilla it down (no offense to our primates), but i just snugged it. on the brightside..my kayak is submarine water tight...(after i siliconed sealed all the rod holder inserts)
PostPosted: Tue Jun 18, 2024 11:00 am
Thanks KungFowlChicken for your response. I left it like that: snug. I think the looseness was a production overlook, unless someone else says the contrary.
I'll be on the lookout for new leaks. Maybe one day I'll have mine "submarine water tight" :D
Cheers
