It is currently Thu Aug 20, 2026 8:05 am
PostPosted: Thu Jul 21, 2022 10:43 am
The scupper holes on my passport 10.5 are not fully drilled out. This prevents my kayak cart from being able to seat into the scupper holes properly. Should I drill them out or will I cause my kayak to leak and take on water? (Ps, I bought the 12.0 passport at the same time and it's scupper holes are not blocked, meaning I can get it on my kayak cart)
PostPosted: Thu Jul 21, 2022 1:17 pm
Sorry to hear that - should have been caught in our factory or at the dealer PDI inspection.... you can have a dealer help - or if you're able - A 1-3/8” hole saw would work best. You can also drill a smaller hole in the middle and use a Dremel tool to open it up to 1-3/8”
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Jul 22, 2022 4:16 am
Thanks, I will try drilling the 1 and 3/8 diameter hole.
