It is currently Thu Aug 20, 2026 8:05 am
PostPosted: Fri Jul 22, 2022 7:17 pm
New passport finally came (damaged but they are already sending a new one) and looking for best way to store it. I have a small 2 car garage and even after cleaning up for the past 2 weeks , it's still going to be a tight fit.
Any issues storing it on plastic saw horses? What I was thinking is store it on the side of the garage right now with the horses (with tarp) while I am using it. But in the winter store it at the front of the garage on same horses. My truck will fit, but not by much so thinking this might be a good compromise.
Are there any problems storing on horses long term?
It looks like this boat was damaged/dropped on the right side. There are cuts and even 2 spots on the seam that are smashed in yet it did not budge at all and is seaworthy . I don't think there is anything wrong with a 2 piece hull like some people seem to think fwiw.
22 Lynx
22 Compass Duo "Liparus"
22 TI "Victoria"
PostPosted: Fri Jul 22, 2022 7:42 pm
Sorry to hear your new Passport was damaged and needs replaced. Bummer.
Your Passport manual (https://media.hobie.com/digital_assets/Passport_Foldout_Manual_Extended.pdf), as with most Hobie Mirage kayaks, recommends two acceptable storage methods:
1. Upside down on a pair of crossbars.
2. Suspended upside down using webbing.
Your use of sawhorses should satisfy method 1 if the sawhorse thickness is at least 1.5" - 2" and the length of each sawhorse exceeds the width of your Passport.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Fri Jul 22, 2022 11:30 pm
Peter
Thank you. What I have should work fine as they are extendable.
22 Lynx
22 TI "Victoria"
