It is currently Thu May 21, 2026 1:40 pm
 Post subject: Anchor Trolley
PostPosted: Fri Jul 09, 2021 11:24 am
I recently switched from a 2019 Outback to the Mirage Lynx. I fish a lot of inshore areas in SWFL and was sold on the Lynx's lighter weight (had leg/foot surgery in April, lighter makes car-topping a lot easier solo). I was wondering if I could install the Hobie-brand anchor trolley, like I had on my Outback, on the Lynx. I know it's less durable and has no inside-hull access, but would screws damage the boat? If it is possible, what would be the best way to go about mounting one? The way I have the seat set and my kayak crate tied down in the sternwell both overhang the scupper holes, covering where I would stake out with a push pin. I avoid anchoring in super heavy current.
Thanks in advance,
-Todd
 Post subject: Re: Anchor Trolley
PostPosted: Fri Jul 09, 2021 3:50 pm
There is not Trolley kit for the Lynx at this time. Due to the type of construction, you can not drill to fasten hardware. There were limitations on molded-in inserts due to molding complexities. Possibly a DIY solution tieing into the bow and stern handles or a traditional anchor. We are still thinking about that one.
PostPosted: Sun Jul 11, 2021 1:50 pm
Matt,
I had some ideas. How strong are the molded in gear tracks? Would a Yakattack GT Cleat installed in the track attached to an anchor hold safely? Or I'll move my crate up and stick a stakeout pole through the scupper holes. Could moderate current on the flats, pressing the pole against the sides of the scupper holes, damage the hull?
PostPosted: Mon Jul 12, 2021 2:11 pm
Couldn’t you make use of the inserts, fore and aft, that are for the Hobie H-Rail? Be sure to use the proper sized screws.
PostPosted: Tue Jul 13, 2021 10:22 am
I would think the track is strong enough.
PostPosted: Fri Jul 16, 2021 10:43 pm
8:30 min lynx anchor trolley
https://youtu.be/Lt4COtdPrW8
PostPosted: Mon Jul 19, 2021 7:49 pm
I haven’t felt the need to anchor in a couple of years. I just use the pedals to hold position to get a few casts to an area and if there’s no bite move on down the line, but I also don’t do bait and wait
PostPosted: Fri Jul 23, 2021 8:18 pm
Wonder why he used the rear insert and accessory track as his to attachment points. Front and react inserts would have made for a much longer and more practical anchor trolley in my opinion.
PostPosted: Tue Aug 03, 2021 8:49 pm
I’ve always heard that it is a bad idea to use a stickpin pole through a scupper hole. When I bought my Lynx I asked about an anchor trolley. As I have not had a pedal boat before this, my dealer suggested that I might find using the pedals to hold position would work in lieu of using an anchor.
PostPosted: Thu Aug 12, 2021 8:43 am
I plan to try a stick-it pin with the lanyard looped over a ram ball in the forward sail mount port.
I find that I only use my anchor trolley (on my other kayak) in the forward position because I always want my bow facing into the current. I think the sail mount will accomplish the same thing since it's on the centerline. It's also close enough to unhook easily.
PostPosted: Fri Dec 17, 2021 2:15 pm
https://www.hobie.com/forums/viewtopic. ... 46&t=69351
PostPosted: Sun Mar 20, 2022 1:05 pm
Has anyone used the YakAttack SwitchPad with MightyMount to install an anchor trolley? If so, what adhesive was used?
PostPosted: Thu May 18, 2023 8:23 pm
I fish in a river with my kayak, and I think an anchor trolley is a must-have because, without this set-up, I would be constantly irritated with position movement and bad angles to cast. I am using the Yak-Gear AK1 Deluxe Anchor Trolley Kit, and I have had several exciting experiences with it. The current on the river doesn’t stop me from going fishing. I can even maneuver the bow of my kayak to turn into the current smoothly.
