It is currently Thu Aug 20, 2026 8:06 am
PostPosted: Fri Jul 02, 2021 5:07 am
Hi, just want to know if it's possible to install a SideKick Ama Kit for sailing stability on a Lynx?
PostPosted: Wed Jul 07, 2021 9:28 am
The Lynx is not designed to be drilled into, so would have to mount to existing mount points. I don't believe this will work.
PostPosted: Sun Oct 24, 2021 7:13 am
I have mounted the armed site kit to my H Crate, I Don’t now how to attach a photo
, can someone show how I can add a photo, I write on my iPhone 12 Pro Max
PostPosted: Mon Oct 25, 2021 12:10 pm
Teddy Jensen wrote:
, can someone show how I an add a photo, I write on my iPhone 12 Pro Max
Instructions to attach photos:
https://www.hobie.com/forums/viewtopic.php?f=18&t=8574
Jacques Bernier
http://www.hobie.com/
PostPosted: Tue Oct 26, 2021 12:56 am
Jbernier wrote:
Teddy Jensen wrote:
I still don't get it? why is it so difficult to ad a picture?? there should be a button, for just to click and uploade picture?
PostPosted: Fri Jan 28, 2022 11:04 am
My solution:
PostPosted: Sun Jan 30, 2022 12:05 pm
Looks like a terrific set up. I had two questions I hope you can clarify… The fixed tube on the sidekick set is 24 inches long. On the Linyx, the H rails are about 29 inches apart. How are you able to mount the rigid tube? Mine would be too short. Also, do you know if it's possible to buy the accessory you used in the United States?
PostPosted: Tue Feb 01, 2022 5:27 am
There are two options, one is to extend the original pipe from the Hobie kit, the other option is to make a new pipe, which turned out to be easier, although there is one detail that makes it a little difficult to implement. The holes into which the akas enter are conical and must be made additionally on a lathe.
The original SIDEKICK - XBAR MIDDLE is 61cm (~24")
This pipe from the pictures is 76cm (~29.9") I made this tube for Hobie Outback so that the factory rails can be used without having to add H-RAIL UPGRADE FOR OUTBACK as I showed in this video.
My opinion is that the tube should be 78 cm (30.7"), so it can be fixed directly behind the seat.
I can check how much the transport costs to the USA will be and I will write to you.
PostPosted: Fri May 13, 2022 2:12 am
Hi, great mod. Totally cool. I checked out the link but it doesn't seem to work for me. I'm in London, UK, if theres any chance you could help me get a pair of those rail clamps I'm happy to pay you upfront. ( :
PostPosted: Tue May 17, 2022 10:03 am
I'm in Bulgaria, so you're not very far. :)
Just to finish some of the tasks that have accumulated, because I spent a month on the Greek islands with my cat and now I'm wondering where to start. :)
In the second part of the video I put the shots with one Lynx and one iTrek 11.
PostPosted: Mon Apr 22, 2024 11:32 am
Another solution for mounting the Sidekicks on the Hobie Mirage Lynx 11.
PostPosted: Sun Nov 24, 2024 11:31 pm
One more solution:
