It is currently Thu Aug 20, 2026 11:59 am
 Post subject: Bubbles in deck pad
PostPosted: Sat Sep 11, 2021 9:29 am
Got a couple big bubbles in the deck pad and response from Hobie was I should be able to put an invisible hole in it to let the air out. No hole is invisible and seems like I would be opening up a passage for air and water to get in it it doesn’t adhere back down. Anyone else have to do this yet?
 Post subject: Re: Bubbles in deck pad
PostPosted: Mon Sep 13, 2021 6:42 am
I've done this with similar pads (not my Lynx) and it works fine. Pop the bubble with a pin and squeeze the air out. The adhesive on the back will hold the pad to the deck once the bubble is gone.
PostPosted: Mon Sep 13, 2021 10:50 am
Use a straight pin. It wont ause a problem. Mine went away when I left it in the sun a little while and rubbed them out.
PostPosted: Mon Sep 13, 2021 1:20 pm
You are lucky ,mine has bubble under plastic and hobie reply it is just cosmetic...maybe i should try pop it with a pin..... :lol:
