It is currently Thu Aug 20, 2026 6:54 pm
PostPosted: Sat Jul 10, 2021 5:14 pm
Given the ACE-TECH construction what is the recommend hull attachment point for a mirage drive tether or “leash”?
Please and thank you.
PostPosted: Mon Jul 12, 2021 12:21 pm
Looks like the best spot is the cargo hold-down hardware in the bow area.
PostPosted: Mon Jul 12, 2021 7:12 pm
Thank you Matt. I was looking at it again today and thought the same thing. I’ll give it a try my next trip out.
PostPosted: Mon Jul 12, 2021 10:48 pm
Another option might be the mast socket. Remove the screw on the underside and pull out the socket. It helps to put a line around the tab on the aft side of the post to give you some purchase since it’s a tight fit. Create a small loop of line around the post so that a section of the loop sticks out after reinstalling the post and you have a sturdy attachment point. When reinstalling the post, pay attention as there is a thin tab on the bottom cap that aligns with a groove in the post. I installed the one below as an attachment point for a stand up assist strap.
PostPosted: Tue Jul 13, 2021 8:16 pm
Great idea, I’ll give that a try as well.
Thank you.
PostPosted: Fri Feb 11, 2022 11:48 am
I put an Outback rail cut to size across and attach the drive leash to it.
