It is currently Thu Aug 20, 2026 3:23 pm
PostPosted: Fri May 05, 2023 3:41 am
I want to find out what the”ASA Polymer outer skin” on the Linx is. So I can get the proper epoxy. I want to attach the anchor trolley hardware to the outer skin with epoxy. If anyone has done it, what were the results.
PostPosted: Sat May 06, 2023 4:05 am
Straight up I don't think any epoxy is going to be reliable under those conditions.
If you cannot attach a nut on the inside to a bolt, how about using a wellnut?
2014 Hobie Outback set up for rod and longline fishing
PostPosted: Thu May 11, 2023 6:48 am
I ran into a problem affixing an anchor trolley to my Sport last year. I got advice here and ended up using both wellnuts and rivets. The use of rivets makes the installation permanent.
