It is currently Thu Aug 20, 2026 8:06 am
 Post subject: Lynx drive well moves
PostPosted: Wed Apr 30, 2025 10:56 am
I took my 2024 Lynx out salmon fishing today on the Willamette River and I started to hear a knock like a stick was hitting the hull but after further investigation, I found the front part of the drive well is slightly loose and creates a knocking sound when pedaling slowly as I troll. I have used the 2024 about 10 times and I have a 2022 that I have used more than a 100 times without any issues. Has anyone else seen this or is there a way to tighten the drive well?
PostPosted: Fri May 02, 2025 6:23 am
If you are referring to the click and go assembly, yes, you can tighten up the Allen head bolts, but need a round headed Allen wrench due to to the off angle needed to tighten it.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri May 02, 2025 11:35 pm
Thanks for the replay but it is not the click-n-go assembly. I am talking about the entire oval insert that the drive sits in. The front portion is slightly loose and can move about 1/16 to 1/8 and there doesn’t seem to be a way to tighten it.
